  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Configure a MACsec encryption cipher suite:
    macsec cipher-suite {gcm-aes-128 | gcm-aes-256}
    The default cipher suite is GCM-AES-128.
    Ensure that you configure the same cipher suite on both MACsec peers.
  3. Verify the configuration:
    show macsec status {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Configure the 256–bit MACsec cipher suite on the port 1/3 and verify the configuration.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#interface gigabitEthernet 1/3
Switch:1(config-if)#macsec cipher-suite gcm-aes-256
Switch:1#show macsec status 1/3
                                   MACSEC Port Status
      MACSEC Encryption Replay  Replay   Encryption Cipher CA  MKA-Profile MKA
PortId Status Status    Protect Protect                                    Connect
                                W'dow    Offset     Suite  Name  Name      Status
1/3   enabled disabled enabled  50 ipv4Offset(30) AES-256 mkanka extreme   pending
The system displays the following error message if you attempt to configure a cipher suite on a port that is not MACsec capable.
Switch:1>enable
Switch:1(config)#configure terminal
Switch:1(config)#interface gigabitEthernet 1/2
Switch:1(config-if)#macsec cipher suite gcm-aes-256
Error: port 1/2, Port is not MACSec capable. No MACSec configurations allowed on port
The system displays the following error message if your hardware does not support the MACsec 256-bit cipher suite.
VSP-4900-48P:1>enable
VSP-4900-48P:1(config)#configure terminal
VSP-4900-48P:1(config)#interface gigabitEthernet 1/12
VSP-4900-48P:1(config-if)#macsec cipher-suite gcm-aes-256
Error: port 1/12, MACSec cipher-suite cannot be modified on port. Cipher-suite is by default AES-128
The following table defines parameters for the macsec cipher-suite command.
Variable
Definition
Configures the cipher suite for encrypting traffic with MACsec.
The supported cipher suites are:
  • AES-GCM-128, with a maximum key length of 128 bits
  • AES-GCM--256, with a maximum key length of 256 bits
The default is the AES-GCM-128 cipher suite.
